All American Five
All American Five
J'ai trouvé par hasard cet article
Voici le lien : https://en.wikipedia.org/wiki/All_Ameri ... y_attempts
Intéressant
Marcel ( Membre 162 )
Intéressant
Re: All American Five
In restoring the Canadian sets that use a 35L6, one could remove the heat producing dropping resistor in the heater string and directly replace the tube with a 50L6.  If you wish to keep the set original, this resistor frequently shows signs of extreme heat stress.  A 2-watt resistor was common.  A 5-watt will offer a much greater safety margin when replacing.
I don't know about you Joseph in Utah, but here in Québec the line voltage is around 120 volts, sometimes at night mine goes up to 124, once I have seen it at 128!!!
This result in a way too hight voltage for the filaments, so a bigger droping resistor or if available in a radio that one use often replace the 35L6 by a 50L6. Unfortunately those tubes are becoming rare.
For the radios I uses a lot I replace the 35L6 by a 50C5, using a scrap loctal tube after removing the tube I weld in the tube's socket the needed solid wires from the octal socket to a miniature socket and in goes the 50C6. Not very elegant but very efficient and I have plenty of those!
The original idea came from Jean Marcotte from an article he published in our newsletter.
For my part, I replace the 35L6 with a 50L6 everytime I encounter one in a five tube AC-DC set. The total filament voltage being 121V I figure the higher line voltage won't harm the tubes too much, specially when the set sits on the shelf and runs only once in while for a demo.
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 15 invité(s)
